Re: Advise for a noob boat owner!
Welcome to iboats
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
There are quite a few things that should be done.....<br />Is there a service record available as to what was done & when?<br />You should get a service manual for your engine & drive....<br />But, here are a few things that should
really be done:Change your oil, replace the water separating fuel filter....<br />Remove drive & grease u-joints, check gimbal bearing for smoothness, grease all zirks on drive & transom shield.....<br />Drain drive & replace with new gear lube, check for any sign of discoloration in lube or metal on magnetic drain plug.....<br />These are the must do's, but there are alot more that should be done.....<br />The service manual will have a full list of what should be performed.....<br />Since this boat is relatively new to you I would probably do them all, so you know what was done..<br />Lastly, the condition of the driveshaft bellows should be thoroughly checked & the water pump impeller in the drive probably be replaced.....<br />At the top of the page is a red 'search button'.....There is alot of info. in the archives on this subject....<br />As far as hesitation .....With the flame arrestor off, (engine off) pump the throttle....Does gas squirt out? You may have a bad accelereator pump......JK
