1993 celebrity 4.3L
- Jul 2, 2007
- 53
Got the dreaded news yesterday about my 93 that's been in the shop for several weeks after water was found in the cylinders and crankcase. Motor was completely broke down and tested and everything checked out fine. Manifolds, risers, heads, block all solid. Only explanation was that it must have come in through exhaust (flappers were gone) and an open exhaust valve. After putting it all back together, mech said it fired right up and no water in oil but after a few minutes, it started hammering somewhere in the bottom end. Most likely a result of the water in oil causing internal part damage.
My life and financial situation right now has me in a tough spot. We owe way more then the boat is worth in it's current condition. My options are sell it and keep paying on something I don't own or invest more money (I've allready blown $1200 on an unfixable problem) in a new motor that I really can't afford. The frustrating thing is the boat is really nice, well cared for and has under 300 hours on it. I hate to just "give it away". The lower unit, and top end mechanicals are in great shape.
Has anyone dealt with Rapido marine on a reman motor? From what I've seen online they seem to be the most reasonable and seem reputable. They have a short block on ebay for around $1400. Would you all recommend going with a short block and using my current heads since they are good or go with a long block. I think Rapido only charges and extra $150 to go from short to long and get the heads.
Appreciate you all letting me cry on your shoulder a bit and appreciate any advice you can lend.
