advice on trailer axle adjustment
alexc
Trailer bunk extend 6" past transom which was ok, I use it as a step to climb onto boat. But decided to move boat/winches back. Marked original axle location for reference. Moved axle back and now have 7% tongue weight (after many tries) which is good. Measured axle from reference line, one side is 3/8" further back. I know i have to adjust to make it almost even but ...... How would this affect the trailer when driving? Boat is 20' and trailer is single axle with brakes. Thanks.
JB
Re: advice on trailer axle adjustment
Hi, Alex.<br /><br />With a 3/8" difference the trailer will tow a little off center and tend to pull the rear of your truck slightly to one side on braking. <br /><br />It should be a small effect, but I would adjust it to the same distance from the hitch to each hub, +or- 1/32 to 1/16".<br /><br />Good luck. :)
rwidman
Adjust it as close as you can. You will save on tire wear and gas mileage.
