Advice needed on Christine 1990-15 HP 2-stroke that was never actually used but has the original gear oil
GregWA
I'm trying to buy this motor but the guy just admitted to me he took it out fishing with the original 30-year-old gear oil.
He bought it at an estate sale and took it to a boat dealership the guy at the dealership said to replace the impeller because might be cracked due to being so old. So that's all the guy did he replaced the impeller. You would think he would replace the gear oil.
My question is should I be leery about buying this motor now that I know it has been used under load with 30 plus year gear oil? the guys honest I don't believe he used it extensively but still he took it out fishing and used it under load.
GA_Boater
You are guessing. You have no idea how old the lube is. The seller is not the original owner.
If you buy it, drain the lube and check for water mixed in. Replace seals if needed, put in the new lube and go fishing.
Welcome aboard.
GregWA
The engine is basically brand new. Some Elmer Fudd bought it and never used it. Sorry for the thread title it's supposed to say pristine instead of Christine but apparently you can't edit posts on this website unless the post is fresh.
So my question is if somebody runs a motor under load that has 30-year-old gear oil what could the consequences be. Again I believe the guy that he only took it out fishing one time.
Oil that has been in a gearcase for 30 years works the same as if you put it in yesterday.-----The gearcase is a sealed container.
GA_Boater
If you read posts before hitting reply, that doesn't happen. Besides, I thought you were equating the motor to a 1958 Plymouth Fury.
