hi !
when approaching lowest gliding speed my steering gets stiff and you need to hold the steering wheel, otherwise it would by itself turn to the right. at trolling speeds as well at high speed the steering is easy - so i played a little with the trim tab at my outboard ( evnriude ficht 150 ) . it was set at 4deg right - it seems to be the maximum adjustable. i resetted to 2 deg right with nearly no effect.
when i understand correctly - when the steering tends to move to the right you have to give more right trim on the tab and vice versa, correct ?
do you also have a stiff steering at the threshold between displacement and gliding speed ?
thanks for any inputs !
