Re: Adjusting Control Cables
You have to split the inner cable slack in half. If there is 1/2 inch slack in the inner cable 1/4 on reverse side and 1/4 on the farward side.<br /> Cable disconnected move the control handle into farward full throttle, slowly return handle to netrual detent. place a mark on the cable end guide at end of plastic connector. Do the same in reverse, again mark cable guide at end of plastic connector. You will have 2 marks on the cable guide(metal sleeve at end of cable). Then place a mark between the 2 marks, this marks the neutral position. You must do the same with the shift lever. Then connect the cable. All you are trying to do is put to center the slack of the cable and shift lever. The photos in manual makes it simple.
