Adding tilt/trim Gauge to 1995 88spl Rude?
ShawnQ
I am looking to add a tilt/trim gauge to my 1995 88spl Evinrude.<br /><br />I have looked at the gauges, and they are fairly cheap ($25-50). They all say that I must purchase an adapter if my engine didn't originally come with a tilt/trim gauge.<br /><br />Anyone have any idea where I can find this 'adapter'?<br /><br />Thanks!<br />Shawn
rickdb1boat
Re: Adding tilt/trim Gauge to 1995 88spl Rude?
If you have a T&T sender, it will be located on the port side of the motor bracket down low. Raise the T&T to see it. Or do you know you don't have one and need to know where to get one??
ShawnQ
Honestly I'm not sure.<br />I went out to look just now, and it is too dark to see.<br /><br />I assume that since it is a SPL model, it probably doesn't have it (but I could be wrong).<br /><br />If I remember correctly, the SPL is the 'no frills' version, which was available with no tilt/trim, and no VRO. So, it is basically a 'base' model. Mine does have tilt/trim from the factory though.<br /><br />I'll check tomorrow a little more when i get some light!<br /><br />Thanks<br />Shawn
Hooty
If the sending unit isn't there, and I'd bet it ain't, your friendly OMC dealer has the whole tra-la in a kit. Don't remember for sure but I think about $150.<br /><br />c/6<br />Hooty
