adding tach to '75 50hp
medic2051
I would like to add a tachometer to my '75 Johnson. The manual says there is a wire in the control box for adding one. What do I attach that wire to on the guage, and what else is involved in the wiring ?
Hooty
Re: adding tach to '75 50hp
Is there a three hole receptical in the back of the control? If so, this is where the tach connects. Teleflex makes a tach and the wiring harness for it.<br /><br />c/6<br /><br />Hooty
medic2051
Don't have a unit yet. Wanted to see what was involved before I purchased. I know the Johnson control unit has that one wire already in the control box. Is that a sending wire? I assume I then will have two wires on the tach for pos. and neg.? Any help is appreciated.
sparkroost
should be a grey wire for the pulses. And ust like you thought, pos. and neg., that's it. On the back of the tach there are settings for the number of pulses pr. revolution. Set it to your stators # of coils and that's it(usually 6).
