Re: Adding power tilt/ trim?
Originally posted by Jason389:<br /> ...How about adding the control for trim, since my gearshifter doesn't have the button. Would I just add a switch? Thanks for the info.
Get a switch like this (IBoats example) <br />
trim switch <br /><br />Instead of screwing it to the transom or dashboard, just attach it to your gearshifter, just below the handle, with a cable tie (AKA zip tie, etc) around the handle and the switch (between the buttons). The wire will run down the handle, around behind the control box, then back to the motor. YOu'll also want to add a second, similar switch, back by the engine on the transom or somewhere near the engine, and reachable from outside the boat. So you don't have to hop in to tilt up and down (e.g. when on the trailer) - does this make sense to you? If not, I can try to email a photo of how I have it set up. That way, you can control the t/t with your thumb while your hand stays on the shift/control handle. I've seen other T/T units controlled this way, and I have my hydraulic jackplate control on this exact switch, zip-tied to my control handle.
