Adding ladder to existing swim platform.
skargo
Banned
I need to add a ladder to my swim platform and am looking for recommendations. I have a full platform, seen here,
Drowned Rat
Re: Adding ladder to existing swim platform.
That link is an over the platform ladder. Mine stows under the platform. It telescopes in and slides into it's cradle. There is a black rubber T-handle that you pull over a small stud at the end of the ladder to hold it in place. You can just barely see it in my photo. I've got a better photo of it I think, I'll post in a second.
Drowned Rat
Here you can see how it stows. It's rock solid when it's stowed. Get the 3 step version!
skargo
Banned
That's great, thanks!
JFoshee
Skargo, Did you mount that ladder to your swim platform?? I need to do the same thing and am considering buying the 3 step ladder. Have you had any problems with it wanting to break the wood? My wood is in good shape, but some of my boat passengers are not.:rolleyes:
skargo
Banned
I sure did. No problem at all with the hardware I used. I'm 260# and it doesn't budge.
You can barely see it here!
Here's another shot with it deployed. I used stainless bolts, larger than what originally came with the ladder, that I got used on ebay.
I used large washers and it's very strong.
oops!
DR ....that ladder is fantastic.
JFoshee
That looks great, I was hoping you got the one that mounted under the plat form. That's the one I wanted, but yours dosen't look "out of place". I will consider it when I decide to purchase. For sure if it will hold 260#.
skargo
Banned
Yes sir, it holds 260 no problem. I probably would have preferred the under mount, but I bought it used on ebay because I'm a cheap sumgun! It's a Garelick stainless steel, and I got it for $60 shipped. I did have to buy a $14 bit to drill through it, it was TOUGH!
tschmidty
If you are concerned about it pulling through the wood or such, just get some 1/8 aluminum and make a plate to bolt for the back side instead of washers (well, in addition to washers). 7-8$ for a piece of aluminum stock from Lowes/Home Depot and you can cut/drill it with just about anything..
skargo
Banned
I thought about that, but was wondering about dissimilar metals.
tschmidty
It's not a problem, aluminum and stainless go together all the time. I haven't ever heard of an issue with that, maybe with things that conduct electricity but even then it shouldn't be a problem.
