Re: Adding an electronic ignition
I have a 1980 3.0 liter 181 cubic inch GM motor. I changed the points only one time and that was just because I felt like I should every 15 years or so. I still have the old points, condenser and rotor and I carry a new set Cap, rotor, points and condenser in my tool box but I have never seen any trouble with the simple points set up.
Only clame I have seen is some say idle more even. To me uneven idle is more likely a problem of uneven cylinder comperssion or they have uneven gap on the spark plugs.
I will tell you this I have towed in one boat that made the switch to pertronix. They were skiing and picked up their skier and ended up with the key on while they had lunch. Never Would start after that.
As Boomyal says make sure you get the Pertronix II to prevert the problem from leaving the key on.
For me My engine starts in under 2 seconds idles perfect and since new in 1980 has never had a problem.
I can replace the points and condenser on the water in under 5 minutes with just a screwdriver. Sure I would set the dwell more exact when get back. Actually I also carry a dwell/volt/RPM/Ohm meter whey fishing offshore.
If the Electronics added even 5 HP I may make the switch but for me I see no reason to switch to something that can leave me stranded to get in on a kicker if there is no performance difference.
I hear people talking about constant problems with points and adjustments but in the 27 years I have owned my boat just have not seen a problem.
