Re: Adding a trolling motor to side of canoe
LOL. I will try not to tip. I didnt realize those batteries were so heavy.
Can you explain more about mounting the motor directly on the side of the canoe? I was wondering if this was possible and they guy at the store told me I needed to buy the special canoe mount. I would think if you mounted the motor on the side without a propler mount the shaft would head into the water at a strange angle, no?
I wish I had a picture- that would be easier than explaining. Basically my MinnKota is designed to mount on the transom with the tiller forward and that is how most motors attach. What I've done is take the motor and simply attach it to the side of the canoe roughly even with the bow seat. I used a piece of 4"x3"x1/2" wood to widen the mounting area since the aluminum is only like 1 centimeter thick.What happens is that the MinnKota bracket allows for the motor to spin 360-400 degrees either direction so you just point it the way you need to go and you're all set. The other feature of the bracket that allows this is the 5-position adjustment for trim. You will be able to do this by pressing in a little thumb-sized tab that unlocks the motor when is needs to be raised or lowered. This means that if the canoe is slightly angled in as some are then you can adjust the tilt so that is is very near 90 degrees or whatever you or conditions require.
I piece of 1/2" wood placed in between boat and MinnKota mount
I I / on the inside(since motor is designed for a 1/2-3" transom)
I I /
I
II I<<<This is where the motor is mounted
I
II X<<<This "x" is the prop facing aft
I I
I I
I I
I I
I I
I
It is pretty easy to steer the canoe from the front as when placed on the side in the stern she wants to kick right or left too much. If you're familiar with bow-mount trolling MinnKota then you'll know what I mean. It makes steering easier that way.
I hope this helps out. Bottom line- buy the motor mount for fiberglass and other canoes, aluminum canoes do not require it. If you make sure that you are running the prop as deep as possible then you will not experience issues with the prop wanting to graze the canoe itself. If you run it too shallow it will graze the canoe on turns so be aware of that.
If you don't want to deal with this problem then buy the motor mount. Also if you may consider buying an outboard 4-8hp to throw on the canoe you will need a motor mount for that.
The guy selling it probably has never used one unless you go to a small business sporting-goods store.
