Re: Adding a tell-tale spout
OBJ THANK YOU FOR ALL YOUR HELP - AGAIN<br />I have ordered a new thermostat, temp. switch, gasket. I will replace them all at the same time. When I do remove this, by looking at the parts manual and service manual there is nothing underneath but the cyl. head itself. Will a demon jump out at me? By that I mean it comes off and goes back on by removing and replacing the bolts to this cover. The head does not come off with it does it? It appears that the HEAD has it own set of bolts holding it on, according to the service and parts manual - am I right! I really dont want to screw this seemingly easy task up. You dont know the ARNOLD rule of what wont go wrong will go wrong.<br />jim in day, where do I locate that bulletin that you have mentioned? Thank you too
