squarebobdumbpants
- Nov 19, 2010
- 9
Hey guys. I am looking for a little advice on adding a livewell to my 14' Alumacraft. I plan on using a cooler and building a nice frame around it to make it look good and hide any plumbing, wiring, etc. I have seen setups that use one bilge pump to drain, fill, and circulate. Basically you move the pump and hose where you need it-pump in lake with hose in livewell to fill or pump in livewell with hose in lake to drain. And to aerate leave the pump and hose in the livewell.
I'm sure that would work, but I want to make it more "hands-off." With a limit of largemouth, and a relatively small livewell, I bet the water will have to be drained and refilled pretty often to keep the fish healthy. With the method mentioned above, it would be quite aggravating draining and filling often.
My plan is to use thru-hull fittings for a drain and fill line (running out the transom), with each line having a seperate pump with a fused switch. But... I'm not entirely sure how to go about it. I was thinking of using a bilge pump in the livewell to drain and also aerate. The bilge pump would run to a t-valve with a handle to direct the water. Depending on which way the handle was turned, the pump would either drain the livewell or continually recirculate the water through a spray bar mounted above the water in the livewell. This leads me to a question about the drain line, though...Do they make some sort of one-way valve that would let the water be pumped out, but not allow the lake water to flow back in?
As far as the fill lines goes, I suppose it would be pretty simple. I'm not sure what type of pump to use, though. I think I have seen a pump that actually acts as the thru-hull fitting, with the intake being outside the boat, and the motor itself being mounted to the inside of the boat somehow. I have tried searching here on iboats for such a pump, but there are SO MANY im confused! Can somebody post up a link of the type of pump I would be looking for?
So does it seem like I am on the right track? Or are yall shaking your heads thinking "this guy doesn't know his butt from his elbow as far as boats go. He shouldn't even think about attempting thru-hull fittings:facepalm:"
I'm open for all suggestions!
