Adding a generator to a 1958 35hp Evinrude
nsejaw
I have a 58 electric start 35 hp Big Twin Evinrude. Does anyone know what it would take to add a generator to this outboard? I believe generators were on option on this motor. Thanks,
Jim
bktheking
Re: Adding a generator to a 1958 35hp Evinrude
Lots of money and searching, you are better off with a solar panel to charge the battery than trying to find this setup.
R.Johnson
Not that it matters, but trying to remember if these were 6, or 12 volt systems.
bktheking
56 was 6v, 57 and later were 12v
nsejaw
bk! I actually like the idea of going solar...I'm sure it would be cheaper, greener, less time and maintenance...hmmm.....:cool:
rolmops
I did it on one of my '57 sea horses.Between the bracket,the generator,the belt.the larger box cover and the rectifier it was about $350.( I was lucky to be able to use an old ford rectifier).
What I got for it was interesting, a nice time spent fiddling around with my outboard and very little charging power because they will only charge when you are above 1800 rpm.
A small trickle charger will do a better job and is about 90% cheaper.
