add finger ports? v4 looper
looper power
like Dhadley said, put 93 or newer pistons and rods in your 120-140 looper. well, why not add the finger ports to the block that go along with them :) that should really wake her up. where do I send the block?
Dhadley
Re: add finger ports? v4 looper
You can add them to a V4 but they wont be behind the liner like a V6. There's not room. Youll add them with a ball end cutter and actually cut a groove in the sleeve.<br /><br />Actually, there isnt room for them in a V6 open deck (behind the liner) before 1991. The 91's have the added material to the block casting.
looper power
any opinions on sending the block to a porting shop that does that? if I'm gonna bore my small bore looper to 2.0 , why not add finger ports? right? but where, thats the question..?
Dhadley
Lets start at the begining. What are you going to do with the motor? What kind of rpm are you looking for? What kind of boat?<br /><br />The shallow finger ports will help but probably not like you think. You'll have to be turning some pretty good r's to see any improvement.<br /><br />What heads are you going to run?
