I am trying to replace the adapter to powerhead gasket and I have followed the manual and removed every bolt that it says but when i go to lift it off onle the front actually comes up. In the back it has 2 bolts that you are supposed to remove the nuts from and I did that but appears that the bolts could be frozen in place due to salt water corrosion. I have tried everything to knock them loose but that are in such a difficult position. Any way to free them or is there possible something else stuck?
