Acceleration problem with Merc 20hp
TarHeel
I just did some rewiring and carb and fuel pump cleaning on this engine. If I accelerate quickly, it bogs down and shuts off like its not getting enough fuel. However, if I slowly increase the speed, the motor feels like it "catches up" and runs fine at full throttle. The gas is fresh and the vent is open on the fuel tank. The plugs are new too.<br /><br />What could cause this problem?
Waco
Re: Acceleration problem with Merc 20hp
fuel pump? have you tried pumping the ball while you increase speed?
Pursuit2150
Throttle linkage adj.!!!Fuel line obs.<Check primer bulb.
