I have a f115tlrd Yamaha
I took boat last sept. after sitting 3 weeks. First thing i do is fill it up with fresh gas.
We get a mile up the river and it hesitaes and back fires?
After this the boat would not plane. Stuck on 300rpms.
Turn around and go back to dock.
Change fuel/water seperator, fuel filter.
Take it back out it and the boat would plane but rpms would not go above 4200.
So i take it in to a buddy who does boat repairs.
He says bad gas!!! I agree.
He drained all of the gas. Cleaned the tank.(removed sending unit)
He test the boat and says it is fine.
I take boat out 2weeks later. Same problem!!
I call him and let him know.
I take it back to him. He water test it and he has the same issue.
Wait over the winter till spring!!
So he sent the injectors to be cleaned. Changed all of the filters(including vst)
Water test the boat. Says it good.
I take it out a week later. The boat is running better but doesn't get out of the whole very fast and now the rpms are jumping around. The will vary from 4400-5800.
Currently the boat is slow to plane and rpms are sitting at 4200?
I have bought a tank and new fuel lines.
My plane is to take boat and try this.
My guess it is a bigger issue.
How do you no if it is a fuel pump? How do you know which one?(high or low)Can they be intermitten?
Any ideas are welcomed
