A1g2 reseal question
Mcfltfyter
I noticed a little oil in my bellow last year and I'm trying to figure out how far I want to go with seal replacement. Do all of these seals typically fail at similar times? I'm kinda lazy and swore I was going to reseal the whole thing this winter, but the ice is disappearing and I just don't wanna. Would it be stupid to just replace the input seal?
The boat was new to me last season, so I pretty much have to do impeller, gimbal, u joints, etc. anyways.
achris
More fish than mountain goat
What year and serial number is the drive? How many hours on it?
It's not a difficult task to replace just the front seal and o-ring, if you follow the manual. As far as the top box is concerned, the only other seals in it are the upper drive shaft seals and the top cover o-ring. If you've pulled it apart this far it's a 20 minute job to do those as well. But, likely you'll find something else in there that needs attention, so beware the Pandora's Box you open up!
Chris.
Mcfltfyter
Chris.
It is a 2007 OW843360 and vessel view shows 333hrs. It is extremely tempting to just buy a new drive and be done with it.
bbook83
I am with Rick on this. I had never opened up a Mercruiser drive before, but did so a year ago on a unit with three times the hours of yours and replaced the input seal only and it is going great with no further leaks. For under $50 you can do a lot of boating and save the replacement drive for well down the road, unless you find the Pandora’s box achris described.
Mcfltfyter
Is oil in the bellow a death sentence for the bellow, or can they just be cleaned out and last a while?
achris
Mop it out, no harm done...
Replacing that front seal isn't a hard job. If you do end up going 'the easy, but expensive, route' I'll send you my address and you can ship the old drive to me. 🙂
Chris...
Stinnett21
I had that seal and yoke replaced at 1250 hours. Now at 1506 still cranking with no oil in bellows.
Mcfltfyter
I ordered an upper seal kit and I will just push back some important stuff to make it happen. Next winter if the boat needs any work, it's going in the garage. My wife will complain so much I know I'll get the work done just to shut her up.
