Re: A water leak though the transom
Ok, so I undid one side of that bracket and let it swing down. Are those bolts up inside the lower bolts on the transom assy? They seem tight as hell, could the drive just have a bad seal?
Ayuh,... That's really nothin' to report, 'n there's little more to be said,....
If it's Leakin',... Somethin's Wrong....
Close inspection of the area, as it's leakin' is all ya can do....
ID the leak,...
Then tear it apart to fix the leak...
The nuts you took off, hold the inner transom plate to the outer transom housing,...
The little plate is sorta a big washer to spread the load to the wood...(on a Merc, that's different)
In that area, there's the transom housing gasket, 'tween the outer housing, 'n the fiberglass,...
Those rarely go Bad, 'n leaks are usually from rotten transoms...
There's also the exhaust y-pipe, or down-pipe,... it's usually some sorta o-ring, 'n rarely goes Bad, unless corrosion is present...
And,..
On a Merc, there's the hyd. manifold in there,... ain't sure how OMC did it...
No need to bump this,... next move is Yer's....
