a quick question
howster
coil wire shooting fire to motor from under the rubber boot. do i need to replace the wire or seal the boot with something? if i can seal it what can i use? its on the coil side and looks like it had some type of putty or something in there thanks guys :)
magster65
Re: a quick question
Odd. Maybe the coil socket is too close to the engine. I've sealed mine up with an electrical sealer that looks like clear silicone that doesn't set up. Mine was doing the same thing until I sealed it. Now that I'm thinking about it more, that may be an indication that the plug leads are going bad (too much resistance).
johnkc
yep, too much resistance.replace the wire set and make sure you have the correct spark plugs at the proper gap.but verify that the coil tower is not cracked first.
