This question may sound dumb but I'm a novice at timing engines, on a omc 3.0l motor 1986...<br />1. when using a timing light at idle which tooth or dip do I use to time my engine, ya know the timing gauge looks kinda like sharks teeth, do I use the pointy side and if so which one, or do I use the indented ones, if so which one...<br /><br />2. In my manuel it says set the dwell from 31 degrees to 34, does it matter in this range what number to use, it seems my engine reacts to the slightest degreee change..<br /><br />3. Do I keep setting the timing mark and then adjust idel to about 600-700 rpm then repeat the process over and over?<br /><br />Any help would be great thanx a bunch.
