a little outdrive help please
gofastcrazy
i have a 94 merc 4.3 alpha one v6 balanced shaft and thunder bolt ign,( hoe do i know what gen this is) well i did not winterize it and this happened http://i266.photobucket.com/albums/ii279/gofastcrazy/boat stuff/DSCN1234-1.jpg
well i burt up stuff in the out drive and the shift cable too http://i266.photobucket.com/albums/ii279/gofastcrazy/boat stuff/DSCN1230.jpg what parts are back here that i need to replace and does anyone sale a kit,http://i266.photobucket.com/albums/ii279/gofastcrazy/boat stuff/DSCN1233-1.jpg
i bought a new engine and exhaust man's and bellows , but i still need the exhaust flaps. which ones do i need and where do i get them and how do they go in.
oh and one more question,when pulling the motor ( i am use to doing cars,i took all the bolts out of the bell housing is this wrong) do i leave those in and take these out http://i266.photobucket.com/albums/ii279/gofastcrazy/boat stuff/DSCN1235.jpg
ziggy
Re: a little outdrive help please
bummer
1st place to start at.
all the questions yer asking (and you have a lot) can be found in the oem service manual. it's a must have item to service your drive/engine package. you'll probably need two s/m's. the drive is 14, pick and choose to find your engine app... ya can find a s/m in the adults only section at the top of the i/o page.
after ya read that, the specifics can be answered individually.
ENSIGN
You sure did F U Those bolts have to come out,don't lose the springs and fiber washers under the bell housing. If you took the bolts out of the transom shield remove both sides and reseal or you're going to have a searious leak.I would recommend that you get a FACTORY service manuel !
bigskiohio
Master Chief Petty Officer
put the bell housing bolts back in and remove the two bolts and remove your outdrive then the front mounts at the stringer. then it should pull out. the flappers you will replace when engine is out.
Don S
Click Here for the complete OEM service manuals for both your engine and outdrive.
You will need #18 for the engine, and number #14 for the drive.
gofastcrazy
working on it guys thanks for the help.... what about the parts.i need a shift cable and all the bellows.
Ayuh,.... Either Here at iboats for Sierra aftermarket parts, or your local / on-line Mercruiser Dealer for the OEM stuff....
