eavega
- Apr 29, 2008
- 1,377
I have a 1960 Johnson Seahorse 10 HP (QD 21) which I am trying to bring back to life. I have read the "Awaken a sleeping outboard" FAQ, as well as several other online references on what to do. One thing all of them mention is replacing the water pump impeller. With my Seloc Maintenance guide in hand (apparently so I had something to kneel on!) I removed the lower unit, opened the water pump housing, and found a fine collection of rubber pieces which with a little imagination might have resembled an impeller once in its life. Now, here is my problem; The Seloc guide says to remove the water pump plate (I would presume for cleaning and such), but I cannot do it. There is a pin in the driveshaft that the impeller key sets on. I can't get the plate around this pin. The Seloc manual warns not to pull the driveshaft out, else risk having to open up the gear case to set things right again. Now, when it gets to re-installing the water pump, the picture that they show of the lower unit clearly has the driveshaft removed! Is removing the driveshaft the only way to get this plate out, and is it really necessary to remove the water pump plate at all (i.e. are there gaskets or seals that need to be replaced when changing out the impeller?) Any help or advice would be greatly appreciated. I can post pictures if that might be more helpful.
Rgds
-Eric
Rgds
-Eric
