Let me start by saying that I have recently bought my first boat. It is a 15' omni-pro fishing (tri-hull) boat. The boat is fairly new (2003 with some gel coat issues) and it is equiped with an early '70's model Merc. 850. I have spent a few dollars to have the motor gone through and it starts, runs, idles fine. The compression is good.
I only have a couple of issues at this point. I have tried to read as much as I could on this forum but I have only succeded in confusing myself!
The first issue is with the steering. It is frozen up (the cable is bad) and I need to replace it. I am fairly certain that I can do this job myself, however I am not sure which kit to order. The only issue I see so far with removing the old system is the getting the old cable out of the motor (I guess I need to move the motor over a little to get enough room to remove the cable from the motor). So my question is how do I know which kit to order for my steering?
The second issue is with the throtle cable. It does not seem to be tight enough. When you push the throtle all the way forward, the response in the motor does not match. The throtle lever(?) on the motor will only go about half way. You can push it forward with your hand and does just fine.It is as though the throtle lever looses it's responsiveness half way to full throtle. I am not sure how to adjust this either.
Any help or insight would be greatly appreciated.
Thanks!
Thanks!
