I have 115hp Johnson (1984) and I am replacing the fuse panel on the boat because the old one was in pretty rough shape. I'm not looking to rewire the whole boat, but I can't seem to find the 12+ from the ignition. I am guessing that it broke and the one I'm looking at is indeed it.
Where does this run back to so that I can locate it and replace as necessary? Does it run back to the outboard or just to the control box? I have everythin else done, but no main juice! I used a seperate battery to test everything as I switched things over so all of the accessories are working, just need to get it powered by the 12+ from the ignition.
Thanks
Thanks
