So after buying a used sterndrive last summer, I just changed the prop for more stability and torque, however, when I tried to move it, it gave just a little on the shaft, maybe 1/16"-1/8". I have checked all parts, removed the prop 3 more times, checked the thrust washer etc, but the same result. Prior to installing the prop nut, I put pressure on the aft adapter and the prop did not move at all, but when I finished torquing the nut (55 ft lbs), same result. Am I getting frustrated over nothing, or is this a real issue. TIA!
