confused1234
- Aug 31, 2010
- 8
I am new to owning my own boat,I just got a used Champion Bay Champ and in the battery compartment it has three batteries. 1.The battery switch has off on the left and right sides and a 1 on the bottom and (ON) on the top of the switch, what selection should it be on? 2.Should I turn it to the off position after I charge the batteries while the boat is in storage and then turn it to the on position when boat is in use? What position should it be on when I am charging the batteries? When I got the boat it was in the (1) position and everything worked except the trim tabs, when I put the switch on (ON) everything works.
Thank you for your help.
