Re: A drive data cable?
Xcusme said:
"There is an arrow, of sorts, on the top of the connector over the outside pin. Is that where the red stripe on the cable is supposed to line up with?"
Yup, it should be.......
Ok, at the top of the connector, on the motherboard, is a little triangle (arrow) beside the top pin. This is where the red edge if the cable is lined up with. As well, the red edge is on the outside (left as you are facing the computer) of the connector on the A drive. This is where the little elongated triangle is stamped into the top of the female connector.
I turn on the computer and get a solid, uninterupted A drive lite. I will now, once again, reverse the connector at the A drive and see what happens.
I have not yet checked the bios (F9 on boot?) to make sure that the drive is declared 1.44. But unless it changed by itself, this drive used to work. I think it quit working after I disconnected cable to install a second harddrive a while back.
While I have your ear Xcusme, I am going to install a new 80 gb HD on this unit. I have two tiny HD's, the primary one is only 4-5 gb's and it is so full I cannot even defrag.
I will move the current primary drive to the secondary position and retrieve any data later. I will remove the current secondary drive and toss it. I have already copied everything on the secondary drive to my new external USB 2.0 drive.
When I install the new drive, is there anything I should know about reinstalling Win2k? Should I just boot and install the cd? Been a while since I did this.
EDIT: I just reversed the A drive cable, as I mentioned, I got a momentary drive lite while windows was loading, then nothing. I inserted a disc and did not get any lite. I think both of my A drives are shot..???
Whichever way I connect it, I am now getting this message once windows loads;
"the drive or network connection that the shortcut 'Microsoft Office.Ink' refers to is unavailable. Make sure that the disk is properly inserted or the network resource is available then try again."
