I recently purchased a Mariner (yamaha built) 40hp, engine no is Mariner 40e 6e9l 405360 which I am told is 1982 model what I want to do is this, I want to run the engine on the water, it starts and runs fine in a drum, compression I am told is 130 in each cylinder it does have issues with the lu seals need to be replaced (a bit of water in oil not much just makes the oil a bit off colour) also the prop is stuck solid, therefore the need to test the engine before spending serious money on it. It is hooked up to a 14ft aluminium boat new now my dilemma is I do not wat to bolt the engine to the transom at this stage will the c lamps done up very tight be fine for the test and when I test it what should I look out for btw the engine pumps heaps of water of course if the engine is a keeper the the impeller will be replaced anyway.
thanks
macca123
thanks
macca123
