I wanted to ask a couple of questions regarding winterizing techniques/ theory and I will try and be brief. These questions relate to things that I have read regarding different winterizing techniques. My motor is a 5.0
1. If a motor is run on muffs until it reaches operating temp, and then the block is drained BEFORE adding AF, would it not be a bit dangerous to start a hot motor without having any coolant in it? I realize that the impeller will supply water quickly, but will it be soon enough to keep from potentially damaging the engine?
2. If you add AF to a running motor via muffs (as compared to simply filling the block) can residual AF seep into the cylinders when you shut the motor off? I realize the same condition would exist when operating and shutting the down on the water as well. I guess what I am asking is if exhaust pressure helps keep water out of the engine. I know it does with Jet skis, but I am not sure about Mercs. Thanks
