Thats a reference to an old joke. If you got it...we are on the same page humor wise...
New to the page, and respect the great responses I've seen. I've read the Seloc, its great, but not really good enough.
A new to me 89 225 VRO on a custom 24 CC, nice boat, good deal. Sat for 2 years, unused.
Trial run - started right up, idled rough, but very slow and quick to overheat. I tested on freshwater lake, so I shut the motor down, and cast a line to buddy on shore who waded through the muck to get me back to the trailer (eventually).
I was concerned I roasted the engine with the brief overheat, but she looked good, and a quick compression test was in the 90 - 92 range on all six.
I figured I would start with the lower unit- replaced the water pump and t-stats 2 days ago. Today drained all the old gas, disconnected the VRO wiring harness and put in fresh fuel and oil ( one quart to 12 gallons x 2 ).
Testing today, found a nice trail of water from the tell-tale, an improvement, but was very hard to start...maybe 30 attempts before she caught. The starter gear would seem to drop off the flywheel prematurely. Lots of strange noises. Add some choke, no choke, etc, etc, etc. Then out of the blue, started nicely, idled beautifully, only ran her up to 2500 in neutral, but sounded great. Shut her down after 10 minutes. But she would not restart...again. Took her home, spark at all 6 plugs. Took the cover off the carbs just to take a look. All butter-fly's look the same...clean...and moved in unison with the throttle.
A few concerns..
The exhaust was coming from the exhaust housing instead of the prop (just above the cavitation plate), which makes me think I mucked up the gaskets on that exhaust jig during reassembly of the LU. Does this really matter?
Why so hard to start? Is the premature drop of the starter a sign of weak battery, and if so, could a weak battery cause a hard start because of a low rpm? It seemed OK, not like a car in winter kind of hard start, but maybe these engines like alot of speed to start?
Whats next to check, and any other useful advise is greatly appreciated,
Thanks,
Mike
A few concerns..
Thanks,
Mike
