I have a 99 merc four stroke serial numb. Og907201. It starts with the touch of the button idles great goes in gear great. The problems start when i get to 3/4-full throttle it wants to bog down and die. Dosent cough or sputter kinda growls. I can run at 1/2-2/3 all day long with no problem until i throttle up. Now, when i am ready to stop when i throttle back it also wants to die. I can shift it to nuetral when this happens and it stays running. Or if i throttle back very slowly i can keep it running. When this happens the primer bulb is firm and pumping it has no affect. Ive replaced fuel lines, tried merc quick clean/seafoam and stabil every fill up. Only thing i havent done is tore the carbs apart and gave a good cleaning. The lync n sync process is keeping me from doing this. I have rebuilt carbs and am halfway mechanically inclined. I did drain the bowls and sprayed different carb cleaners in and let it soak. Any help or ideas to get me headed in the right direction would be greatly appreciated. If you need any more info let me know.
