99 johnson outboard oil/fuel ratio
wilde1j
Re: 99 johnson outboard oil/fuel ratio
50:1, 16 oz per 6 gal of fuel.
tashasdaddy
what Johnson 2.5 or 225? it makes a big difference
bob johnson
really?
I knew years ago they had motor where they required 25:1 ratios
butin 1999 I would have thought everything would be 50:1 after intital break in period.
what motors require something other than 50:1?
bob
wilde1j
Ficht and E-Tec absolutely must not be fed premix ... the only modern 2 stroke motor exceptions I know of. With those motors, fuel never sees the crankcase at all. Everything else is 50:1 TCW-3 . 25:1 (and higher oil content) was before the mid sixties. The only other oddball I know off is the British Seagull and Neptunes, which used 16:1, and smoked accordingly.
