Hello-
I'm having some trouble with my trim /tilt. I have the boat on a trailer, and when I trim the engine all the way up, after about 10 minutes it is all the way back down. After I trim the engine all the way up, if I listen closely, I can hear the hydraulics slipping. I tried checking the fluid and when I open the fill plug a small amount of fluid comes out, so I assume that the fluid level is OK. (?)
I had the boat in the water last weekend and while I was cruising along I decided to trim the engine up a little. The hydraulics did not hold, and it quickly slipped back all the way down.
Any ideas what the issue could be?
Thanks for reading.
Thanks for reading.
