99 Johnson 40hp Alternator Output
Blue_Escape
Hi,
just considering setting up a multi battery (start & deep cycle) charging system in the boat and wanting to know what the typical charging output from a J40TPLEEA would be. Also what is typical idle and WOT RPMs for this model?
Thanks
John
Silvertip
Re: 99 Johnson 40hp Alternator Output
Alternator output is 12 amps at wide open throttle. Idle is about 700 and wide open throttle range is 4500 - 5500. Prop for the higher end. 5800 is even better. Just so you know, you will have to run for miles at wide open throttle to add any significant charge to the deep cycle battery. If you are long distances between spots it can help prolong run time but you should have an on board charger and plug into shore power to keep the deep cycle fully topped off.
