99 Glaston no fire
samt
A friend of mine just bought a 99 Glaston. It has a 4 cylinder Volvo motor. Has electric ignition and a Holley carburetor.
It cranks, but when you release the key from start it doesn't have fire anymore.
I can't get 12v to the purple coil wire unless the starter is cranking. I assume the grey wire is the tachometer.
Fishermark
Check and make sure the safety switch is not off. Then check for inline fuses under the dash.
