'99 Evinrude 70HP E70PL4SS* +22 MPH issue
Savage17
I have a 99 Evinrude 70 HP that I have put a lot of love into. She starts right up, purrs at Idle, and pushes my 18? 186 Sea Chaser great, at slower speeds.
​last Fall, the first season I had the boat & motor, I was having stalling issues when I tried to push her over 20 MPH, she would just DIE. Stop dead so fast the wake would catch my Carolina Skiff and lift the whole *** end up in the air. Also, it was leaking a lot of gas. I found that there is a Hose from the top of the 5032905 - Fuel Vapor​ Separator that connects to the 5030689 ? Silencer Cover, that was pumping a LOT of fuel into the Air Intake Silencer Cover and draining down into the lower cowling. I Removed this hose from the Silencer Cover and stoppered it with a ?? piece of blank steel rod and applied a hose clamp to it. Again, she ran FINE until ? throttle in Neutral and in gear until hitting the 20 MPH mark.
Over the winter, I disassembled the 5032905 - Fuel Vapor​ Separator, and found no issues with it, the needle Valve or float. I then replaced the 5032323 - Fuel Filter​, and added an External Water / fuel Micron Separator, and NEW Fuel lines tank to separator, and separator to Motor. I Replaced the spark plugs as well.
This week, I?ve got her in the test tank, and she is NOT stalling at 1/2 throttle like last year, but rather pulsing / Throbs like the Fuel / air Mix is not right. (If I could figure out how to post a Video, I would) The Engine Torques, sways and will not run Smoothly past ? to ? throttle, but does not stall now. When shooting Carb cleaner into the 5030680 ? Throttle Body, it smooths out for the duration of the spray, then resumes its pulsing / Throbbing & Torqueing.
I am at a loss here, and prepared to just drive her <slow ***> slow all year.
Any info would be greatly appreciated!
Savage17
Impeller and gear oil both changed, tattle tail working as it should.
jakedaawg
Your going to need a manual and the ability to get the codes. Also going to need fuel pressures.
daselbee
Ok...that is the rev limiter. You cannot run a 4 stroke above 2500 UNLESS it is in gear. The EMM senses that the engine is in neutral, and will throw the system into rev limiting mode.
Savage17
Daselbee, I threw her in drive and was able to get it past 3/4 throttle before I got showered... thanks for the info on " rev limiting mode"
Time for a test drive!
Thanks all
