99 evinrude 225
wantagh mako
is this a good engine,any problems i should know about ? thanx kevin ps is this a fitch moter?
bossee
Re: 99 evinrude 225
Hi,<br />You may want to follow the thread with<br />Topic: "New 99 Ficht, ADVICE NEEDED!"<br />earlier.<br />IF the outboard you are interested in is<br />a "ficht" (I do not know).<br /><br />/Bo
dick
Re: 99 evinrude 225
Find the model # and post it here .That will tell us what you own.
wantaghmako
Re: 99 evinrude 225
HI MY ENGINE IS AN OCEAN PRO , IS YOURS AND WHAT PROBLEMS DID OR DO YOU HAVE?
dick
Re: 99 evinrude 225
E-Evinrude<br />225- hp<br />T-Electric start ,Trim and Tilt<br />X- 25" transom<br />EU-1997<br />D-model run<br />So it looks like you got a carb engine and not a Ficht.I don't mind those big looper engines but they are heavy on the fuel. I wouldn't be using it for trolling as they tend to carbon up.
clanton
Re: 99 evinrude 225
Check the upper bearing housing bolts, if loose, remove, clean bolt, clean threads in block, loctite red, install bolt, tighten with torque wrench. Check the upper engine mount bolts, the ones on the outside.
wantaghmako
Re: 99 evinrude 225
thanx alot the info is very helpfull. hope you had a grate holiday thanx again kevin
