99 evinrude 150 abnormal vibration occasionally during operation
Sodcutter
I have twin 150 evinrudes and the right engine will occasionally shake and vibrate violantly while running. You can throttle back to idle and it runs normal, then throttle up and immediately does this again. After a few times of throttling up and back to idle and letting it idle for a few minutes will go back to normal operation. It has done this twice now and not sure what is going on. Anyone ever have this happen or have any idea whats going on?
Chris1956
Honorary Supreme Mariner
Perhaps the shift assist switch is sticking, causing the motor to run on only 3 cylinders? Perhaps the SLOW overheat detector is killing spark to 1/2 the motor?
Sodcutter
Thanks Chris, I know not what either of these two things are but looks like I'm going to get an education. Is there somewhere I can go read up on these parts?
Chris1956
A service manual will discuss the topics.
The shift assist switch is located on the shift cable on the starboard side of the motor. If you disconnect it, that would eliminate it as a cause. It may be hard to shift out of gear, with the switch disabled.
SLOW is activated when one of the cylinder heads detects an overheat. If you disconnect both temp sensors in the heads, that system will be disabled.
reiddo1
My 2000 Johnson 150 at 2500 rpm would shake violently when both cold and warm. All references on this site indicated SLOW as being the problem and I proceeded to check it out but quickly found that a number of spark plugs must have been failing, since a complete new set overcame the problem. Are your plugs in need of replacement? It is a relatively inexpensive replacement and if it does not cure the problem you will at least have a backup set.
