rjv57chevy
Thread starter- Joined
- Oct 16, 2003
- 7
First I need to say I bought this boat used. The previous owner let it sit for a time but he took it to the dealer and had $600 worth of repair done to the engine(cleaned the carbs, replaced fuel pump, etc) before he put it up for sale. The fuel had gone bad. <br /><br />Anyway, the motor will crank up first crank, idles smooth, a little cold natured but typical for a 2 stroke. It can idle all day long and it runs top end at about 5500 rpm's and runs well. It's when I accelerate under a load (more than one person) it sometimes will go and sometimes it won't. The critical rpm is 1150. When I give it gas if it can make it to 1150 rpm's it will take off. If it goes to 1100 rpms and kinda hangs there it will load up and die. If I turn the wheel so the prop doesn't have to push the whole boat when I accelerate it will take off better. If I'm in the boat by myself it will accelerate okay most of the time. I wonder if the pitch on my prop is too much but the upper rpm's seem to be in the ballpark. It's right where the power band is about to kick in where it has the problem. All the fuel hose clamps appear to be tight also but does have the plastic type. It accelerates with no problem when not in gear. I put new plugs in so I would have the old ones as spares. The stainless prop has a 17" pitch. <br /><br />By the way I'm new here and I don't know all the outboard terms but I know how to work on other types of motors. Thanks for any advice.<br /><br />Lowe 17' Aluminum Boat<br />Rodney
