99 25hp 3cyl Johnson lacking power
hank1219
Motor runs good at idle. Good spark. Good compression. I have motor on a 14' welded jon boat. Motor is lacking power on the take off. Just bogs down. I don't think the boats to heavy. Any suggestions?
Honorary Supreme Mariner
Has the oil injection tank been thrown away on this motor ?
jakedaawg
Did it ever run well on "this" boat? if not, what type of boat was it on previous? May be as simple as mounting or propping. Also, consider doing a cylinder drop test to verify that all three cylinders are contributing.
Has anyone adjusted the low speed mixture needles ?--------Normally and on many motors they are set at 1-1/2 turn out.-----But on these motors there is a measurement !
jakedaawg
excellent point, forgot all about it
