'99 250 Yamaha SWSII failure
benny914
Just cracked a powerhead and looking for advice. Bought motor used 18 months ago-well maintained, knew the owner, less than 600 hrs on engine etc..Warranty ran out last May. Cause unknown yet but starboard middle cylinder had piston/rod failure. Leaned out due to bad O2 sensor or water? - or maybe carbon???. Is this common with these models? I just heard about two others letting go with a similar problem. Trying to decide whether to rebuild now or repower with 4-stroke (one day in the future). Don't want to rebuild if there is an inherent problem. This is second Yamaha to let go :( in two years (had an '88 225 Yamaha Excel that burned a piston due to oil pump failure and no alarm). My research on the 250's showed them to be very reliable. Any comments are sure appreciated.
John from Madison CT
Re: '99 250 Yamaha SWSII failure
Benny,<br /><br /> Sorry to hear the bad news. If your uncomfortable rebuilding, then go new, but I would stick with a Ox66 EFI Yamaha, like the one you have.<br /><br /> These are generally very reliable motors. Did you run YamaLube and RingFree in her? Perhaps a carbon build up problem.<br /><br />John from Madison, CT
