24gradyexp
- Aug 18, 2004
- 25
I've got a 99 250 EFI Merc with an intermitten ignition problem (Cylinder cuts out then comes back then will cut out again like someone flipped a switch. Could it be diagnosed by hooking up to test equipment at a dealer or should I just do the old process by elimination theory. With that should I disconnect and ground the sparkplug or the disconnect the plug from the ECU and Stator to the coil.<br /><br />Thanks
