!987 Pro V 150 Trim and Tilt Problem
penning72
My trim and tilt stopped working and I'm not sure what the relay looks like. Does anyone have a picture of the relay so I can test it to see if its' gone bad?
penning72
I did that and it went up to a small 1" X 2" black box. Is that the relay? It seems to small.
99yam40
I do not know for sure, but I think that if the motor wires come from it it has to run the T&T motor
, but post up a pic and Someone should be able to respond.
Or just look up the parts break down and see what it shows
mjf55
According to the parts diagram, the relay assembly is part number 6G5-81950-01-00.
You can search for that and look at the images. I would attach it here, but having problems from my phone.
mjf55
No Title
Went and took a picture of mine. I have 1989 175 . You can see the square black box in the center, under the starter and oil tank, that is the Trim & Tilt relay box.
