98 Yamaha waverunner xl won't start??
leewillm
I tried to start my yamaha today after covering her for the winter but she would not start. Starts to crank but only does a second then kicks out. Put full load on battery so not a battery prob. The battery wires and the battery actually got hot as I hit the starter repeatedly and only got a one second kick then stop.
Could be the pump is frozen or the motor is locked? I pulled plugs and kicked it but got the same "try to start" then nada. No grind just start to turn over then lock.
I thouht I would turn the impeller to see if pump frozen as a next step...what am I missing? Even hit it with a little ether to see if the gas was bad. All suggestions accepted gratefully.
wannabemrfixit (kids are waiting)
bigdaddypt
Re: 98 Yamaha waverunner xl won't start??
pull the plugs and try to turn over the motor by hand. it might be that your starter is almost dead. could be a poor ground connection so check that.
