I have a 98 Saltwater Series V4 115 TRLW, I have replaced the following:
water pump
impeller
thermostats
temp sensors
poppet valve
It still overheats at high RPM's above 3000 RPM
the old mechanic I had pulled one of the head covers to check the water jacket, and said it was clean, he did not pull the other one. Soooo, at this point I believe there are only 2 things left, either the other head is clogged, OR maybe it's my TACH is faulty, BUT, I have not looked into the oil issue.
I can tell you this, though, I am tired of taking my boat to guys that say they can fix something WITHOUT water testing it, seems kinda silly, no?
water pump
impeller
thermostats
temp sensors
poppet valve
