I posted a few weeks ago that after rebuilding my powerhead everything ran great but I had a small stream of water comming out between the powerhead and the adapter it sits on. I finally got around to lifting the powerhead so I can reseat it. I found that the gasket between the powerhead and the adapter had blown out around the port where the water enters the block.
Now for my question. My repair manual does not mention useing any gasket sealer on that gasket so when I put the powerhead back on after rebuilding it I used no sealer. This evening when things cool down a bit I am going to put the new gasket on and reseat the powerhead. Is any gasket sealer recomended fot this? And since the last time I seated the powerhead I set it on a dry gasket and the gasket blew do you think I should use sealer this time.
