98 evinrude stalls at idle, when put in gear, and revs up and down by itself
Mwik
1998 evinrude outboard starts fine, then stalls when at idle. Must be reved up to get into gear or will stall, after running great for a minute or so begins reving up and down by itself then bogs down and stalls eventually. Any ideas?
boobie
Re: 98 evinrude stalls at idle, when put in gear, and revs up and down by itself
Model # ???
Haffiman
Most likely a fuel leak somewhere. Increases when 'leaned' out, stalls when flooded.
Mwik
Model no. X50ESLEUS Ser no. G 04345434. 05/97. Power mass 35.8kw 84 kg
Mwik
I see no fuel leaks but will check all lines tomorrow as a starting point.
Mwik
Found a potential fuel leak & replaced fuel filter, can't be that easy, but will try running on water ASAP.
